Technical 1.2 16v engine swap punto/brava
gad3n
Plovdiv
hi guys .. i blew up my engine yesterday :(
in my local scrappy there is a cheap 1.2 16v brava engine and my question is are they interchangeable .. and is it possible to run it with my punto wiring and ecu ... i'll swap the coils, the throttle valve with the steper motor and throttle potentiometer and just disconnect the knock sensor .. just dont know if there is any major difference between the engines need the car up and running in 5 days PLZZZZ help (sorry if english is bad)
10X :) tomorow i'll get the old rusty pickup and soon i'm back in business ... won't run 1.5 bar boost anymore :) ... i'm quite astonished by the way the 1.2 turned out to be quite hard to break :) 15 minutes full throttle 1.5 bar pressure - only one piston damaged between the rings
