im Axle Specialists
Thread Tools
Old 31-03-2008   #1
1.6 turbo engine
hi
would a gt turbo head fit a 1.6 sohc block? or would the manifolds of a gt fit the 1.6 head?
thinking about building an engine with pistons, rods, all balanced etc etc and was just wondered if it was possible.
what sort of bhp could you get running it at 25psi with a t3 or similar size turbo?
cheers for any help josh
1242cc 16v, will have gsxr 750 carbs with megajolt edis ignition puls lots more
jbarragan is offline Reply With Quote Quote
Old 01-04-2008   #2
Trader Rating: 2
davethetrike has donated!
Re: 1.6 turbo engine
Quote Originally Posted by jbarragan View Post
hi
Yes but you might as well use a 1.6 head iirc therer is an issue with the egr valve. Yes the manifolds fit the 1.6.
around 250 to 300 ish bhp
There is a 1.4 304bhp running around at the moment. very laggy, virtually nothing until 400rpm. I'll post the spec up when I get the chance.
The Proton coupe, Evo's lovechild.
davethetrike is offline Reply With Quote Quote
Thread Tools
(G) Punto 1.8 HGT - Turbo Kit/Eaton Supercharger/ 16v Turbo Coupe Engine?? Mooks Punto (Mk2/2b) 29 11-03-2014 13:59
(G) turbo engine chubbston Uno 0 01-04-2004 02:54
anyone looking for a turbo engine? custard Auction Watch 0 04-02-2004 03:24
