Sorry its not an answer to your question but ianother question...does anyone know how to replace the heater control bulbs on a 95 55s please ? its only the blower direction switch bulb that is out,thanks
two allen bolts on the bottom of the heater panel, one behind the middle heater control where when you pull the knob off for the blowers it will have another allen bolt. when removed then you can simply pull the bulb out and place the new one in, be careful as the bulbs are small and delicate. hope this helps you
