So if, like me, you have had your head gasket replaced, should this problem be solved??
yes yours should be quiet it may need bleeding again as i'm about to explain
i have the same problem i have been going on the net trying to find a way of solving this bubbling problem, and try every single way of bleeding the cooling system out and it still remains in the car! so following the advise off of all the websites and fiat themselves i have replaced the head gasket! this now it has been changed, the car starts up better in the cold and doesnt have any steam coming out the exhaust when revving it up! but it still had the bubbling noise coming from it, so i have again tried bleeding the cooling system to get the air out. to do this what i was told is to lift the front of the car about a metre of the floor and then run the car up squeezing the hoses to help bring the air out the top for the filler bottle, after doing this the problem was still there very slighly but noticeably less than before. so i tried it againg and again and the last time i tried it i couldnt hear any noise from insdie the car. the only thing i worry about is starting it up when its cold and it doing it then which seems to be the worst time for it happening! nd then still if it continues apparentley theres nothing you can do fiat has told me! thats just the way they are. but being a mechanic myself i dont except that as an answer! so i asked a couple more people and there is some form of modification that fiat does to them to stop the noise from happening! not sure if anyone on here has heard about that before? but if you have i would love to know what it is, because they wont tell me at the dealer!
so anyone with this problem you aint alone, give the lifting the fron up bleeding a go if not do the head gasket and then try again and if not off to fiat for them bastards to sort it out
erm no i work at fiat and there is no such secret fix or trick to it forget that
as for your dealer i would tell em to take a running hike they sound usless
just a quick question have you had your head skimmed when the head gasket was done this is vital if you want it fixed properly
if so then it simply needs bleeding properly
as your a mechanic i assume you know about both bleeders one on the heater hoses at the back and one on the radiator
you''ll also notice that the rear bleeder is higher than the radiator is
there for if you open it the only thing that wiil happen is air will go in instead of coolant coming out this is were your problem is
what you need to do is
1 fill coolant bottle to very top
2. open radiator bleeder till it comes out and close you now have the radiator bled
3. fill to top again
4. now open the rear bleeder
5. either get someone to gently blow on the top of the coolant bottle or get yourself unless you have one a coolant pressure tester, screw it onto the bottle and slowly pump air in the tank until the coolant just begins to run from the rear one
6. then close it
7. turn the heater to full hot start car and run till warm hold at 3k revs or 5 minuites to clear any left over air pockets listening for the fan to check it's working also
8. allow to cool and top up if necessary
you can see what the point of this excersise is you need to get the water to rise up to the level of the bleeder buy bleeding wilst pushing air into the header tank
things to remember are keep the level in the tank as high as you can so you don't push more air into the system you can always use the radiator bleed screw to let it back down to the max mark afterwards
also if you remove the rear bleeder completely it will make it easier to make sure you have all the air out
you may get a slight noise the next morning but if it goes away in a week or so without you messing with the coolant system it should be fine
if it stays then all i can suggest is that the head gasket was not done correctly or the head was not skimmed or maybe warped or something
the fact your dealer told you that all punto's are like that is disgusting there not and under no circumstances should they make this noise if they are working correctly i'm shocked and horrified that you have been fobbed off in this way i hope you find a decent garage that will take the time to look at your car and make sure it's ok
also nobody try lifting the front of there car that high it's dangerous and it wont work
