Old 02-03-2008   #1
Wipers not parking correctly
I finally managed to get my wiper motor fixed, however now the wipers aren't parking correctly.. what's happening is that the wipers rest above the position where they should be.. e.g. instead of the bottom of the windscreen, they are maybe 4-5 inches higher than they should be.
It doesn't seem as simple as just moving the position of the wipers though, as when they do wipe.. they go below the current parked position and go to the bottom of the windscreen, then return back up to the parked position just above the bottom of the windscreen (as before, 4-5 inches above).
Any ideas on what the problem is?
Cheers,
Adrian
AdrianL is offline Reply With Quote Quote
Old 02-03-2008   #2
Trader Rating: 10
dave has donated!
Re: Wipers not parking correctly
what was your fix?
“The further a society drifts from the truth, the more it will hate those that speak it.”
Old 02-03-2008   #3
Forum Moderator
T14086's Avatar
T14086 has donated!
I assume you took off the motor to linkage rod.
Old 03-03-2008   #4
The fix was the wiper motor being replaced. My father took it out and replaced it but I presume he would of...
Old 03-03-2008   #5
Trader Rating: 10
dave has donated!
was it replaced as a whole unit inc linkage?
was it new or used?
was it from a mk2 or mk2?
Old 03-03-2008   #6
Quote Originally Posted by dave View Post
was it new or used?
No just the motor, it was used, from a Mk1 Punto.. 60sx or something iirc.
Old 03-03-2008   #7
I'd suggest disocnnecting the linkage from the motor and then operating the motor so that it stops in it's proper park position. If the motor has been partially into it's cycle and the linkage has been connected that would explain why the wipers try to clean your bonnet.
I don't mind being wrong, but I hate it when somebody else is right.
rpaterson is offline Reply With Quote Quote
Old 03-03-2008   #8
That sounds about right, I'll let my father know and see how it goes.
Thanks guys.
Old 03-03-2008   #9
Forum Moderator
T14086's Avatar
T14086 has donated!
Quote Originally Posted by rpaterson View Post
link between motor & linkage should be at 9 o'clock position at rest.
also is the wiring same for mk1 wiper motor as mk2
(T) Sei Wipers stopped working Littala Cinquecento / Seicento 1 23-09-2007 10:41
(T) Brava JTD wiper problems, and what models wipers will fit it? Mr Meltdown Bravo / Brava 0 14-01-2006 21:03
(T) Sei Sporting Wipers (How Big??) 2minits Cinquecento / Seicento 1 27-09-2005 16:20
(T) How-to-fit VW Golf wipers on a mk2/2.5 LanciaMad Punto (Mk2/2b) 4 19-07-2005 21:23
JML Parking Sensor cagerrey Lets Talk FIAT 17 17-06-2005 21:07
