oakld
- Apr 27, 2007
- 8
- 3
Hello,
well, replacing head gasket became a service duty on the Punoto's, it seems . Anyway, it was replaced 2 weeks ago on my Punto, in quite remote garage (due to place of breakdown). Now a new problem developed yesterday, a jingle-squeaky periodical sound coming from the engine. I immediately arranged a local mechanic to have a look on that. He took off the air filter assembly and the cover on the cam-shaft and almost immediately found out, that there is no oil coming to the cam-shaft and that the sound comes most likely from the cams itself. He took off the oil distributing tube (marked green on picture enclosed to this post) so to confirm that it's not blocked and that the problem is "bellow". Next it caught his attention, that the head gasket was replaced, so he sticked a wire to the channel and found out, that he can get only about 10cm down through the channel (see attached picture for schematic figure, the channel is figured as nr. 7 position), a distance approx. from the upper side of the head down to the head gasket level. The channel appears to be blocked by head gasket (see red circle in the picture included; my engine is 1,2l 8V, not 16V figured in the picture). He says, that either the gasket is somehow flipped over or it's faulty, i.e. has no hole for the channel!
I would like to know your opinion, because I have to "ship" my car now back to the original garage and if the local mechanic is wrong, I'll have to pay not only for the new repair, but also for the transport. And I wouldn't feel comfortable of false accusation either.
So what do you think? And how's that I made circa 500km in those 2 weeks without breakdown? (well, only cam-shaft was affected, but anyway!). Can somebody confirm that the wire should go through the block all the way down?
Thanks for any opinions and answers!
Regards,
Regards,
