sporting_adz
- Dec 11, 2007
- 64
- 32
I've got a 2001 1.2 sporting and am having problems with a misfire. I was driving along when I lost power and the revs wouldnt go above 2000. I pulled over and restarted the engine, the revs went above 2000 but then revs bounced abit on idle and then wouldn't go above 2000 again. The AA came out and checked the sparks, all sparks are okay, we narrowed it down to cylinder as when we pulled off the HT lead on cylinder 2 there was no changed in the engine running. My engine managment light has been on due to something with the 02 sensor, could this be affecting this? Should the next stage be doing a compression check? Can anyone reccomend a garage in the bristol area?
