![]() | #1 | ||
Join Date: Jul 2004 Location: Cambridge, United Kingdom.
Posts: 1 Thanks: 0 Trader Rating: 0 | Power Steering problem ELX(8v) 2000 reg Hi, As a newbie I would like to thank you all for an excellent forum - it seems to have loads of advice that is relevant :) On to my issue, over the last month or so I have noticed a problem with the power steering - it just cuts out and I have to develop super-muscles to control the car (the wife isn't too happy either) The power steering light does come on just after this happens, but the strange thing is that if you turn the car off and restart it, it works fine (puzzled). Another fact to mention is that this does not happen every time ... I have seen a few posts here relating to steering columns, so was wondering if this is indicative of a steering column fault, or something more sinister (ECU) ? The reason I mention ECU is that there are some other anomolies with the car - 'electronic fault' light on dashboard comes on for no apparent reason (very sporadic) and the car tends to jolt when decelerating/accelerating around corners when the fule gauge is around one quarter ... Any advice would be welcome, and if anyone knows of a Fiat specialist in or around Cambridgeshire could they please send me the details ? Mucho Regards Nick
![]() | #2 | ||
Posts: 14,690 Thanks: 370 Trader Rating: 1 ![]() |
![]() | #3 | ||
Posts: 4,724 Thanks: 8 Trader Rating: 0 ![]() | the ecu problem was to woth the coils packs/spark pluge which causes the engine to misfire. I dont think it has any affect on power steering......could be wrong tho :I EVERYONE- SPRAY YOUR PUNTOS BLACK ![]() ![]() ![]() David
![]() | #4 | ||
Posts: 478 Thanks: 0 Trader Rating: 0 | that recall has nothing too do with steering or even rough running, its suposed too stop the coil outputs from dieing. your problems with your power steering nick sounds a bit tricky too say the least, intermitent faults like that a the hardest too track down in the workshop. -=[uno 1.0ie RAAAWW!]=- -=[fiat tech for what it's worth.]=-
![]() | saviogimmi | Punto (Mk2/2b) | 12 | 29-11-2010 21:23 |
![]() | shotter | Punto (Mk2/2b) | 17 | 30-12-2006 12:45 |
![]() | visualcandy | Punto (Mk1) | 4 | 12-05-2004 13:43 |
![]() | dawozere | Cinquecento / Seicento | 7 | 27-02-2004 16:30 |
![]() | CWpete | Punto (Mk1) | 23 | 14-02-2004 23:15 |
