Technical Tyre Pressures
I've always wondered about tyre pressures!! I have a 1.2 5 door punto 75sx, someone once told me to put them up to 31psi where as someone else said if you put them up as high as that u will be bouncing all over the road!!??!!
the figures i gave you are the offical figures from haynes manual and from the fiat punto owners handbook that comes with the car. 32psi is a bit hard if no one else is in car. of course if you have put diferent alloys on then you need diff pressures
2001 Punto sporting in sprint blue with matching Mr Bump air freshner all together now mmmmmmm
mine are at 38psi normally 15" Alloys with toyo street tires they grip lovely when wet :D
