Technical mk2 punto 1243cc 8v elx
silentbob669
United Kingdom.
Hello,only joined yesterday hoping for a bit of advice!!! i am having problems with my car, at low revs in second and third year there is hardly no power until about 2000rpm. The car has only just started to do this, any ideas??
Cheers!!!:p:p
How long was it since your last service ?. Try one of them Petrol additives to decoke your engine and injection system :) I put some in every full tank of petrol i get.
i really wouldnt expect an 8v punto too pull well at that sort of rev/gear combo
-=[uno 1.0ie RAAAWW!]=-
-=[fiat tech for what it's worth.]=-
My 1242cc 8v ELX seems to pull fine down at 2k. Its never going to be fast, but if the traffic isn't accelerating away I tend to change up at 2k5. I think peak torque is at 4k or so, which means it's never going to be as accelerative at 2k as 4k. I think it's mostly down the car. If you're used to big cars who have loads of torque low down the rev range, then the Punto will feel lesser, because its smaller!
Actually, I find mine will still accelerate (very slow, but it does it) on the flat in 5th from 20mph. I use Shell (non Optimax) most of the time (in 47k miles driven by me, about 1k were non Shell).
Punto Mk2 ELX 8v in Teseo Blue with the electric Sunroof and CD changer, doing 50mpg whilst passing down country lanes
Chris, the peak at 5k curve is the power in kW. The other one is torque in Nm, which actually peaks lower than I expected. Nice to see this kind of info...
About one month ago I received a letter from the FIAT dealer to bring in the car for ECU reprogramming.
Done 2 weeks ago free of charge. Unfortunately the letter from the dealer remained with them and I don't remember the recall number.
It seems it's a bug affecting only (some of the) 1.2 8V Punto's made in 2002.
After this the car drives the same, I didn't notice any change. But I'm quite happy how it pulls even at low revs, and also consumption is quite low.
