FIAT Auto Specialist Team
Thread Tools
Old 01-07-2004   #1
Pressure sensor???
Car just failed its MOT(2000 punto 1.2 8v)due to high CO on emissions test.Apparently the computer had codes for pressure sensor(whats that?) & evap valve(whats that?).
All sounds very expensive but told the lambda sensor wasnt working but thats not the fault as was changed,and the engine light is not on,any ideas? Thanks
T140 is offline Reply With Quote Quote
Old 01-07-2004   #2
thats apsolute pressure sensor, detects engine manifold depression and the evap valve is a valve that evacuates the carbon canister.
if you've ever done a cat test on a mk2 punto you will know their a pain in the ass too pass the fast idle test because the engine wont maintain a steady speed without any load, lots fail mots on high co because of this.
-=[uno 1.0ie RAAAWW!]=-
-=[fiat tech for what it's worth.]=-
kebab is offline Reply With Quote Quote
Old 01-07-2004   #3
Thank you for the reply,apsolute pressure sensor thats under the air cleaner just to the right of the injection(throttle body)unit?
Failed with 6% CO apparently?
Old 01-07-2004   #4
Moderator
ChrisUK's Avatar
Trader Rating: 1
ChrisUK has donated!
Bartender Champion, Wood Firing Champion
My Mot Tester said it wouldnt maintain a contant Fast idle speed so he just ignored it as it passed the normal IDLE and every other test:)
ChrisUK is offline Reply With Quote Quote
Old 02-07-2004   #5
It failed the idle test(high CO),apparently the lambda sensor and the combined temp/air pressure sensor was changed but still the same.Also the computer(examiner)cannot clear the pressure sensor fault as it keeps coming up as soon as the ignition is switched on:(Also the EVAP sensor keeps coming up as faulty as well?
Old 08-07-2004   #6
For some reason 'ECU' kept going through the back of my mind so I tool it off & sure enough green corrosion on 2 of the pins.New ECU & all concerns solved,thanks all who helped;)
Old 08-07-2004   #7
[:0] really, ecu corrosion.
thats well worth knowing for the future, thanks.
Old 12-07-2004   #8
Yep Kebab,bottom left hand pin on connector A was all green/corroded,never saw it until I took ECU off to inspect it,water was obviously sitting in there for sometime but was dry when I looked at it.Seems alot of puntos have ECU faults even though they often record coil fault codes!
Thread Tools
(T) Low Oil Pressure pjp Stilo 39 04-05-2010 03:33
(T) MAP Sensor and Ignition arseofbox Cinquecento / Seicento 6 09-06-2004 20:16
(G) tyre pressure baslaityer Ulysse 11 10-12-2003 19:21
(G) Sensor resistance gtomas Tipo (Classic) 2 15-11-2003 06:36
(G) PRESSURE GROUP Ham Stilo 13 29-10-2003 05:09
