Hi can anyone help.
a few days ago my girlfriend hit a speed bump a little to hard and snapped the exhaust away from the manifold and catalyst, being quite far away from home she continued to drive it home even though very loud! This caused the hot exhaust gases to burn through the lambda sensor cable which in turn made the engine management light come on.
She has had exhaust replaced but engine light is still on?
I have had a look under the car and there looks like there is space for 2 lambda sensors one above the cat and one below.The one above the cat looks like its connected correctly but the one below the cat looks like the garage who fitted it has put the old one back in because there are loose burnt off cables coming out of it? do i need to get a new lambda sensor?
Also today her power steering light has come on, city button doesn't work and steering is a little heavier.
She has noticed ticking/crackling noise coming from the steering wheel, when she turns the wheel.
She has a w reg 1.2 16v punto
Any ideas?
Cheers in advance
Any ideas?
Cheers in advance
