Rob_M
I have a 1999 1.2 16v Sporting which has starting problems.
First noticed that if you turn the key to the first position on the ignition and listen carefully something is being energised. I think it is the injectors or fuel pump...not sure which. The car will start ok. If I do not get this noise then the car will just turn over but not start. This happens intermittantly. This morning I've gone to start the car but it was completely dead...nothing ? Even the key won't open the central locking. I tried spares and 'red' key to no avail. Could it be the battery ? What would explain the intermittant energising of the injectors/fuel pump when it was running ?
Any advice would be appreciated.
Rob
Rob
