Technical Rear Light Cluster
markf27
United Kingdom.
Anybody know where to start when replacing the rear light cluster, i've got the part from Fiat. Found a panel near the rear headrest to get acces to the mount but don't know where to start from there!
As far as I can remember, it is pretty clear in the handbook how to remove the light cluster. It takes a couple of minutes at most to undo a couple of bolts and the whole thig comes away in your hand. Doesn't the new one simply replace it?
Red Stilo 02 5 door. Blue Punto 02 3 door.
Have u got a mk1 or mk2?
EVERYONE- SPRAY YOUR PUNTOS BLACK
David
I've got a mk2, I've lost the manual but I worked out that the key in the spare wheel set removes the bolts from the inside of the light cluster, the it's prety simple from there!
