Technical startng problems
jerry y
i have a 53 plate 04 punto 1.2 8v
i have had a problem with starting right from buying the car from new.
from time to time when you get in the car from cold to start it it just won'nt start. the engine turns over quickly and sounds as if it is going to start. turn the key off and try again and still it won'nt start.try as many times as you like it still won'nt start. leave it for 5 mins and then it starts first time.
had it back to the dealers when it was under warranty but they can'nt find any thing because it's running. it has to be not working for it to show up any electrical problems with sensors. connect it up to the diagnostics and it costs £68 plus vat now that its out of warranty.
had the R.A.C. out and it started for them as soon as they turned the key, it had been left before they arrived.
the A.A. said it was the crankshaft sensor, they gave it a clean with some W.D. 40 and it started, although it had been tryed and then left before they came. not convinced it was that.
any help would be greatfull:cry:
little pip says the ecu is shutting down because the starter is drawing more power than is needed. but i get no warning lights in the dash.
r.a.c. say it is electrical interferance from, now get this, my telegraph pole.
thats a doozie.
more help needed please
Similar problem with my 03 (53) plate Punto.
Just seems to be when it is cold.
Luckily my drive is on a slope, so I can 'jump' it off 99% of the time if it won't start.
Any advice would be helpful.
Regards,
fiat_fandango
I have also a big prob with this....
Iv got a 2001 sporting, trouble starting in the mornings, but it would eventually manage to get going.
The battery decided to die on sat so i assumed that was the prob. Got a bosch battery today (90 nicker by the way!!!) and now the started seems as though its seized...
fortunately im a student an housemates have cars, but dad coming down sat to help out an fix...
Any ideas greatly appreciated!!!!
Ant
thats a doozie.
thats fn hilarious here take a lone of my axe you know what to do
and it isnt to chase the rac man
Right im just replacing the starter motor... heard they jam or something.
Is there a difference in a standard starter motor for a 1.2 16v say elx to a sporting both 2001 model??? I ask as the gearboxes are diff and im not sure if that affects the bell housings shape etc.
im guna try get one off ebay but the only descriptions you get are 1.2 16v mk2 etc.
Any one any thoughts?
Interesting that it was bad starting from new.
Most likely cause is wrong mixture at start up. Normally a huge dose is given engine i.e. as in the old choke system. As the ecu is responsible for this it would normally calculate the dose by engine temp and engine speed, so cranking speed and temp low = high dose, cold tick over = less dose etc.
A poor software system in ecu could be the problem, but I think Fiat would have sorted that out. Ecu reading temp incorrectly is another possibility.
Temperature sensor is another possibility. Its a pity that you are left to sort it yourself rather than putting right by the "experts". If I had that problem I would probably try a few things i.e.
Put a large dose into the manifold before starting from cold.
On a seperate occasion use a variable resistor instead of the temp sensor before starting from cold. Just try and get a pointer to where the problem might be.
