minkymouse
- Jan 28, 2008
- 1
- 1
Hey, i had new gearbox for my active sport 8v "52 plate, fitted last summer as the diff went on the old one, since around september when you put it in reverse it makes a grinding noise. Also recently when you even pull away it makes a loud knocking noise when you change gear. It also makes knocking noise when you take you foot of the accelarator when decreasing speed.
Does anyone reckon this new gearbox is broken????? ps had new clutch fitted at same time if this makes a difference.
Thanks in advance
Thanks in advance
