Hi
When the car is has just moved off in 1st - and maybe doing approx 5mph, changing into 2nd gear and then letting the clutch up fairly sharply, but not to hard, produces a loud clunk from the front nearside of the car and can be felt through the clutch pedal as well as the rest of the car really.
Other symptons of the same type of clunk, knocking and rumbling can be made when putting the front nearside wheel of a lot of rough road at slow speed and a the same rumbling can be heard. The same isn't heard when putting the front offside wheel over the same bit of rough road.
We have been under it a lot, changed a split rear engine mount underneath but this made no difference. ARB bushes seem fine, CV rubber seems fine. The clunk isn't made when bouncing the suspension anywhere. Tyre wear is fine. All other engine mounts appear fine and engine can't really be rocked. Springs look fine and shockers appear to be fine (after bouncing not clunk is made)
The noise isn't made when bring the clutch up slower and really smoothly, but something is happening when the car is just rolling from first gear (5mph) then selecting 2nd and when the clutch is brought up, a loud bang/clunk/knock is heard.
We jacked up the wheel and rocked it and their seemed a bit of play in it. We've ordered a new wheel bearing (£20 motor factors) and by hitting the top of the tyre inwards with a fist when jacked up the same clunk could be heard.
Would the driveshafts or wheel bearing cause this clunk by doing this and is there anything else we can do to resolve it.
Any advice from the experts is really appreciated. Thanks.
