johnlumley
Hi Guys,
New to Fiats, just bought the lad his first car and having a bit of a problem..I'll list the facts and hope you can come up with helpfull ideas...
1. Bought car 3 weeks ago, ran AND idled perfectly. 70K miles, 1242cc 8V.
2. A week ago, head gasket went, lots of fuel/water/antifreeze went through the engine/exhaust. Got a mate (mechanic) to help.
3. Changed head gasket, cambelt, tensioner, rocker cover seal, engine oil, filter, plugs, HT leads, air filter, skimmed head before re-fit, all decent kit, no cheap stuff - Bosch etc.
4. Engine and all looked good internally, like it had been well maintained etc.
5. Engine now idles roughly/imbalanced, but car drives nicely (maybe underpowered?. Starts fine too, but dips too low & comes back to an imbalanced idle again.
6. Took it for a good thrash on the motorway to get it hot, settle it & clear it out, but no difference.
This engine ran and idled perfectly, now there's defo something not right.
I've read about Lambda sensors causing idle problems - could the water/steam have damaged it?
I've read about the CAT being damaged with the "trauma" ... is that possibly the problem.
Last detail, when I high-rev the car stationary it revs high, then drops (a bit) then rises again, and repeats, with regularity as if it is being switched up and down.
Please help if you can, I'm out of knowledge and dont want to keep changing parts unnecessarily.
Many thanks
John
Many thanks
John
