Take it to Fiat mate, its not worth messing around with safety devices, especially ones that could explode whilst your driving down the road, may just be a case of needing the fault code re-set, also it could be the wiring loom under your seat (£40 job from Fiat) or a new Airbag ECU which costs £200 from Fiat plus fitting or £100 from breakers.
no, i swapped my wheel from standard to a sporting and had to drive to halfords halfway through with the airbag off to get a 24mm nut. hence the light has stayed on as a security measure. all i need is for them to turn the light off ahhhh.
someone once said theres a couple of wires in the loom under the glovebox that cause the problem.....
my uncle had the problem on one of his mk2's, he "uncrossed" them (i wish i could remember exactly what it was)
