bane_car
Hi all,
First of all Merry Xmas and Happy New Year!!!
I own a 2001 Fiat Punto 1.9 JTD ELX, and in the last couple of weeks my pre-heater warning light (amber light shaped like circles of wire, located within the RPM dial) has been going on and off for about 10-15 minutes after I start the car.
Let me point out that I always start the motor "properly", i.e. I first turn the key to contact position and wait until this light switches off (i.e. diesel is heated) before actually starting the motor, and never before I've seen this light being on during driving.
I suspect that low outside temperatures might be the cause of this (it's consistently between -2 to -8 Celsius here, maybe even lower during the night), but I would still like your advice - if this is the beginning of a more serious problem, I'd like to fix it before it becomes much more expensive and leaves me stuck in the snow somewhere.
Before you ask - I did try to consult the owner's manual, but unfortunately I only have an original Italian version, so the only thing I could make of it (after using online translators) is that if it's on for more than 60 seconds, this light can signify some sort of fault in the fuel heating system (If someone owns an English version I'd appreciate if you confirm this bit). In my case the light is only on for a few seconds each time, but this still has me worried.
I would appreciate your advice on this, many thanks in advance.
