Old 28-12-2007   #1
Exclamation Worth buying ? :)
Is this worth buying ?
it increases BHP right ?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MESE:IT&ih=016
chris_VW_1987 is offline Reply With Quote Quote
Old 29-12-2007   #2
Trader Rating: 1
alexGS has donated!
New Zealand
Re: Worth buying ? :)
Quote Originally Posted by chris_VW_1987 View Post
I was fearing that it would be one of those resistor-things
As it stands, that probably would give you at least 5bhp at a guess. What price for 5bhp, I wonder...
-Alex
'15 Giulietta 1.4MA, 14 Abarth 500C Esseesse, '08 500 Lounge 1.4 Dualogic, '08 G Spyder, '71 850 Coupe in bits...
alexGS is offline Reply With Quote Quote
Old 29-12-2007   #3
Serbia
Fiat punto 75 Cam Shaft ???
oktopod is offline Reply With Quote Quote
Old 29-12-2007   #4
Just another nutter
Munkul's Avatar
Munkul has donated!
the 75 camshaft has slightly longer duration (IIRC, something like that) than the ones in the 55 and (early) 60 engines, they are all interchangeable (although they may need re-shimming)
which means that it will give slightly better power and torque, i think the agreed figure is around 5 bhp
i have one sitting at home to be sold, no-one wants to pay my price for it....
Munkul is offline Reply With Quote Quote
Old 29-12-2007   #5
Moderator
ChrisUK's Avatar
Trader Rating: 1
ChrisUK has donated!
Bartender Champion, Wood Firing Champion
Quote Originally Posted by Munkul View Post
I know someone who may buy it if your not being to greedy and I can pick it up when we swap our wheels . He wants to put it into his 1108cc Sei Sporting.
ChrisUK is offline Reply With Quote Quote
Old 30-12-2007   #6
mmm i may buy this tbh is it hard to install ?
Old 30-12-2007   #7
Just another nutter
Munkul's Avatar
Munkul has donated!
nope, but ideally you should torque down the shaft caps when re-tightening, plus you NEED to check clearences between tappet shims and the cam lobes, with feeler gauges,and get it re-shimmed if necessary.
it took me about 3 hours (very slow work, though, and i made it hard for myself) to do mine, but i was lucky, all the shims were within tolerance.
plus, if you have a later punto 60, apparently they already have this camshaft in, stamped "899" (or 866, depends which way up you look at it, forgotten which one is correct)
mine already had an 899 cam in, it was a 1998 model - i had already swapped the cams before i learnt that it already had the right one in
Old 30-12-2007   #8
Moderator
ChrisUK's Avatar
Trader Rating: 1
Lol 3 hours work for nothing I bet you were p***ed off
Old 30-12-2007   #9
Just another nutter
Munkul's Avatar
Munkul has donated!
Quote Originally Posted by ChrisUK View Post
yup
and stupid me, i forgot to line the timing up properly, so much of the time was spend lining up the crank positon and looking at haynes manuals
if i were doing it again, it would probably only take an hour, including checking tolerances.
(G) buying a stilo belfast_lad Stilo 29 23-02-2007 14:57
(G) Worth buying? the frog Multipla 8 26-05-2004 01:47
(G) buying a pandy needafiat Panda (Classic) 14 14-09-2003 00:46
(G) Worth buying for 300 ?? Fiat Modder Cinquecento / Seicento 21 20-02-2003 03:33
