![]() | #1 | ||
Posts: 41 Thanks: 0 Trader Rating: 0 | Car smells like old oil - Help HI, All Wonder if anyone can help. Got my car couple a month ago engine was leaking from rocker gasket had that replaced 2 week ago and engine streamed off. So there no oil leaks. Changed the air filter, Sparks, fuel filter oil, oil filter just before the rocker messed up. but when i put the air blower on all you can smell is oil but there no leaks. So can anyone think what this could be. Fiat punto 1.2 8v team 60 1999 MK1 Thanks Tony
![]() | #2 |
Posts: 83,515 Thanks: 1480 Trader Rating: 10 ![]() | Re: Car smells like old oil - Help are you sure its oil smell and not fishy eggy smell?
__________________ “The further a society drifts from the truth, the more it will hate those that speak it.” |
![]() | #3 | ||
Posts: 41 Thanks: 0 Trader Rating: 0 | Re: Car smells like old oil - Help Hi, Could be not really too sure. Cant see it being the head gasket if your thinking that has only just been done before i got the car. Also fiat did the rocker cover and only found a problem with my cooling fan which was changed and also advice the sump. That why i was thinking it could be the oil which was smelling has it was smelling like this but stronger before the rockers was done. What is the easy way to see if it is the gasket thats gone again or do you think it could be somthing else. Our lass says it smells like someone has died , musty sort of smell. Thanks Tony
![]() | #4 |
Posts: 83,515 Thanks: 1480 Trader Rating: 10 ![]() | Re: Car smells like old oil - Help i thinking heater matrix
![]() | #5 | ||
Posts: 41 Thanks: 0 Trader Rating: 0 | Re: Car smells like old oil - Help Hi, m8 a what lol. Fill me in. Wheres that located and what do i need and how do i check Tony
![]() | #6 |
Posts: 83,515 Thanks: 1480 Trader Rating: 10 ![]() | Re: Car smells like old oil - Help its the little rad behind dash where your heat for heaters comes from, if you go here https://www.fiatforum.com/search.php and put in punto heater matrix, you should find lots of info on it
__________________ “The further a society drifts from the truth, the more it will hate those that speak it.” Last edited by dave; 28-12-2007 at 23:11. |
![]() | #7 | ||
Posts: 41 Thanks: 0 Trader Rating: 0 | Re: Car smells like old oil - Help Would it still on cold or just hot or both if it was this part. tony
![]() | #8 |
Posts: 83,515 Thanks: 1480 Trader Rating: 10 ![]() | Re: Car smells like old oil - Help be worse as its gets hotter, and windows may not demist fully
![]() | #9 | ||
Posts: 41 Thanks: 0 Trader Rating: 0 | Re: Car smells like old oil - Help Hi, yes that sounds right windows take for ever to clear and have always keep it on warm on window setting to keep them clear and back windows alway mist up. Is there a quick way of tell 100% that it is this and any idea where can locate a part for this Tony
![]() | #10 |
![]() | Re: Car smells like old oil - Help check your coolant level has it gone down my car take forever to demist but i put this down to not having air con and breathing lots as i know for sure my cars coolant system is fine also the current weather does not help i use my car regularly and it's perfectly dry inside just steams up especially when i have more people in the car if your still sure it's the heater matrix then go with that for now but other things that may case the dead people/oldoil smell posibly the sump you were advised on is leaking oil onto your exhaust causing it to smell old or burnt also gearbox drive shaft seals can leak onto the exhaust mine did and the smell was awful heater matrix normally smells like sweet antifreeze and makes it hard to breath or if it's been on going for a wile stale cat piss
__________________ 500 door handles fit bravo well chuffed ![]() ![]() |
![]() | #11 | ||
Posts: 41 Thanks: 0 Trader Rating: 0 | Re: Car smells like old oil - Help HI, all update Ruling out the heater matrix has coolent level is prefect no lost, Inside of the car is not wet/damp or anything like that. Has for the sump its not leaking it just no far from it lol. So still not sure why it smells. The smell is 100% a musty smell but not sure why or what. Thanks Tony
![]() | #12 | ||
Posts: 41 Thanks: 0 Trader Rating: 0 | ![]() update part 2 HI, Yes your right m8 just been under car to have look and sump has given and started to leak. smells just like what i getting inside of the car. Cheapest i can find is £38 for the sump and £8 for the sealer off ebay that the right one http://cgi.ebay.co.uk/GENUINE-FIAT-P...QQcmdZViewItem thanks tony
![]() | #13 | ||
Posts: 737 Thanks: 18 Trader Rating: 0 ![]() | Re: Car smells like old oil - Help And I was just abbout to say check the bottom of your shoes, maybe you've stepped in something ![]()
![]() | #14 |
![]() | #15 | ||
![]() | Shminkypinky | Stilo | 6 | 02-07-2007 11:44 |
![]() | whatoncewas | Uno | 49 | 17-12-2006 17:12 |
oil - question for GC | Hellcat | Lets Talk FIAT | 47 | 17-01-2006 13:54 |
Synthetic Oil - Not always what it seems! | oilman | Lets Talk FIAT | 10 | 04-02-2005 00:36 |
![]() | blu73 | Cinquecento / Seicento | 21 | 24-01-2005 10:15 |
