Technical Punto Servicing
Telford, West Midlands
I want to give my Punto a full service after fixing all the problems I could find.
Do FIAT do a service that will check ECU for fault codes, check and adjust idle speed, CO content & valve clearances.
I'd like all plugs, fliuds, filters changin as well.
Do FIAT offer this as a package or do I have to book it in as separate jobs.
I can't tell you how much FIAT might charge for this, but have you considered doing it yourself? You'd save some major £££, and it's all pretty straight forward on the little puntos (y)
More idle speed, CO check and ECU I want done, can do the rest myself if it works out too expensive, just a bit cold at the mo and I don't have a garage lol:cry:
Just want to make sure everything is ok with the the things I can't check myself.
In that case one of the FIAT mechs/someone who actually goes to FIAT garage will probably be more help :eek:
But I'd guess it's gonna run into a couple of hunderd quid- when you consider parts, labour + vat :eek:
