Old 16-06-2004   #1
Drv Side Electric window button
hi all,
The drivers side window buttons don't seem to work.
Passenger side electric window button works fine.
I tried pinching the wires inside the rubber cover by the door hinges, and it worked. A week later it stopped.
The actual button on the driv side has fallen below its plastic bezel. I was wondering (since it seems to be a wire problem) how do I get that rectangular palstic cover off to have easy access to the window buttons? (don't want to break it)
Is it held with clips, and if I pry it slowly will it come off?
Also, are the any pdf's of the haynes fiat manual floating around anywhere? If so, anyone got a link?
Thanks to any that can help.
Also, the engine is leaking oil pretty bad. Had the upper gasket (valve gasket?) replaced, but now its leaking out the side. Is it worth it to replace the gaskets that are leaking myself, or just wait till the engine goes?
DrChoda is offline Reply With Quote Quote
Old 16-06-2004   #2
dave's Avatar
Trader Rating: 10
dave has donated!
replace the gaskets yourself, if you can't afford the 15 for a haynes manual, try ebay for a used one, or amazon they sometimes have used ones.
Please do not Email or PM me asking for support. Post on the forums instead. Your reply may help someone else. Thank you
fiat punto electric window flashboy Lets Talk FIAT 0 18-02-2004 23:36
(G) Lines on passenger side rear most window stubie Ulysse 6 29-11-2003 02:06
(T) Passenger side central locking and electric window Sando Cinquecento / Seicento 4 29-10-2003 01:57
(T) Electric window jambo Punto (Mk1) 7 09-08-2003 20:39
