Old 16-12-2007   #1
Brake Light Switch Replacement
I have a Fiat Punto 55 1.1S, can you tell me a step by step instruction on how to change the brake light switch?
Example shown post #7 Stilo
$driver$ is offline Reply With Quote Quote
Old 16-12-2007   #2
Re: Brake Light Switch Replacement
as per manual.
turn off ignition-
remove panel below steering wheel-
disconnect wiring plug-
turn switch anti-clockwise about half a turn and remove switch.Note position of the spacer and bush-
refitting:
depress brake pedal and hold it in this position-
fit bush and spacer to switch ,insert switch into its mounting bracket and turn clockwise until it clicks back to locating recess-
release brake pedal and allow to rest against switch spacer tab--this ajusts the position of the swith body inside the bush-
now depress the brke pedal again- this has the effect of breaking off the spacer tab and fixes the position of the swith inside the bush-
replce wiring plug and panel
switch on ignition and test brake lights
good luck hope, its what you needed
jaybee is offline Reply With Quote Quote
Old 17-12-2007   #3
Quote Originally Posted by jaybee View Post
as per manual.
turn off ignition-
refitting:
Thanks. Where can i buy a switch from?
From the list, what is it listed as?; http://www.247spares.co.uk/fiat-Punto
Old 17-12-2007   #4
cant see one there,try this
http://www.shop4parts.co.uk/index.cf...catalogue.list
you may have to copy and paste
dont know how it compares price wise but think it would be hard to beat, wouldnt go second hand unless you get some sort of guarentee
Old 17-12-2007   #5
Thanks, what category would it be under; braking? subcategory; brake switches?
Have you used them yourself?
Old 17-12-2007   #6
if you type in the address as it is shown it should take you straight to brake light switch
sorry just checked it doesnt, use the drop down list
Fiat
punto
braking
brake switches
Old 18-12-2007   #7
***** Whore
StevenRB45's Avatar
StevenRB45 has donated!
They are less than 30 quid from fiat i got one for mine from local dealer for about 23-25 quid, I'm a mechanical idiot and it took me about 30 seconds, with a haynes manual, I dont think you have to remove the panel under the wheel, its visible anyway? Also while your down there check for the split pin that attaches the brake pedal to the brake system...if its gone get a new one quick!
StevenRB45 is offline Reply With Quote Quote
Old 18-12-2007   #8
is the switch actualy broken ,,its possible to "reset" the switch ,,simply pull out the plunger all the way,,job done!!
(G) Brake light problem - not bulb egobirchy Panda (Classic) 4 22-05-2005 13:34
(T) Cinq 1 rear tail light - brake light on with lights? h10ndr Cinquecento / Seicento 4 11-04-2005 14:42
(T) Another brake light problem cruisestoke Cinquecento / Seicento 2 01-10-2004 14:31
(T) Brake light staying on when lights on Shakey Cinquecento / Seicento 2 22-09-2004 11:50
