OK so as most of you know I have changed my handbrake cables and now have a very strange problem with my brakes.
While the car is stationary I push the pedal which has almost no resistance at all, but after pumping the pedal a few times it firms up to how it has should be (well nearly, will explain in a minute). However, after a few seconds the pedal resistance goes again unless i keep the pedal pressed or pump it.
Now I have changed the brake fluid, and also the reservoir cap seal was out of place, I reseated it and the pedal is rock solid when pumped as it should be. However this problem still remains I'm losing no brake fluid either
Can anyone help?
Mark
Can anyone help?
Mark
