Not at all...best way to learn is from other peoples experiences
Earth (multipoint) is behind n/s light on inner wing (look down) wether this was cause I cant be sure but been ok since as mentioned............shouldn't of said that,bet they blow again tomorrow
OK, thanks for that. I'll check it out just as soon I can get at the car for 10 mins ...
As for the experiences .... I agree but some of them require a book for completeness!
I have mentioned a couple of other threads here today.
Random engine cut out due to broken earth strap from engine.
Oscillating engine revs on an old Sierra (from when it was almost new and for about 7 years after) that turned out to be a badly fitting vacuum pipe.
4 clutches and a recon gearbox on the same Sierra over about 80k miles which turned out to be simple because the original clutch pressure plate was faulty but had never been changed.
A photocopier that was being prepped for an important demo and woprked perfactly out of the box until we went to get some lunch. Came back and it was terrible. Top engineer that was working on it started diagnosis at level 4 and adjusted everything to fix the problem. 2 hours later, still terrible, I spotted a spare connector on the wireing loom (there were many spares depending on the model) that was now lying suspiciously close to a micro-switch. Had obviously been loose and dropped off giving the initial symptoms but that would have been level 1 diagnosis ...
The VX Omega that started to consume batteries. Anything over 6 months old and the battery would go completely dead over night. To the point where the central locking did not work. The key would not unlock the driver door for some reason to the only way in was through the boot. I became an expert and much more agile than I thought possible .... ended up disconnecting the battery overnight every night.
Did not need the car for 3 days so left it with the dealer for checking. Got a call at 8:15 the first morning saying their electrician had seen this before - dodgy heated screen relay, he'd changed 3 and never had a comeback. I thought it odd for the HS relay to be in play in the middle of summer but went with it. Lighter wallet and come the autumn the problem was back and another battery stuffed.
In the end I realised that this only occurred during or just after wet weather at any time of the year. And then, doing something else, noticed that the wiring to major parts of the alarm system, now being somwhat exposed due to the plastic insulating shrinking with age, were in the inner wing area right beneath the scuttle drain hole ...
Better still the siren was directly underneath a crack that had developed on the plastic scuttle trim panel so that when water was draining away it would seep througn the crack and drip right across the connections.
Problem solved with a good blast of WD40 ...
The boot access practise came in useful when the alarm started to activate randomly and refuse to go off until the battery was disconnected. Once at Midnight as I was passing a truck on the M11 having just left Stansted Airport after a long day working and travelling.
Had to disconnect every night again. I was offered 3 different expert diagnoses, all expensive for a car that by then was worth very little. Thought it best to change the car - but not until I had used it for a couple of track days.
There's material for a whole novel in the story of the engine work on the Omega which ran to 3 months and something over 1500 quid as part of what started out as a cam belt change added to a regular service.
With the Omega, and the Senator I had before that, I was doing quite a few miles so ended up at the service reception quite often dropping off or collecting.
If I had a pound for every time some poor customer with pushchair and kids in tow was told that their nova/corsa/astra/cavalier/vectra needed a new 'throttle body' I could have retired years ago.
But then my experiences with Ford dealers before that was not much better. The wife has had some interesting experiences with Citroen dealers and ... well, I could go on but I don't suppose it would be anything new to you.
Of course I regularly make mistakes in all sorts of areas along the lines of not bothering to check the 'it can't possibly be that' item, though it nearly always is! Now I try and stop myself starting anywhere on the diagnosis map other than the very start.
Shall I offer the central heating and boiler examples ...? No, too far OT and it's late.
Thanks again for the advice.
Grant
