Old 17-11-2007   #1
Suspect Fuel pump failure on this 1999 S 60
This car belongs to the wife and my son also drives it - I do the hard bit and maintain it best I can. Just to let you know I've changed the head gasket, heater matrix, rear suspension dampers, track rod ends and break pads/shoes so I'm not really a novice.
OK. Got a call from my son late at night saying it wouldn't start. I checked it and suspected there was no fuel getting to the engine so I called the lads from the RAC out. I must say I was quite impressed by his determination. He suspected a duff fuel pump and towed it home for us [at 3.00am in the morning].
The local Fiat dealership said 160GBP for a replacement (not fitted). A local diy motoring shop said 136GBP and the local scrap yard wouldn't give a quote without a part number (which I don't have at the moment and the dealers won't tell ).
Before I go to the expense of buying a pump and finding this not to be the fault (which someone else did on this forum). I'd like to be absolutly sure first.
According to the RAC guy he said we had 'power' to the pump plug but my confidence was lacking in this since he started checking fuses after this statement . I've since checked the wiring diagram in the Haynes manual and the colour codes I'd be interested in checking is the +ve line to the pump (brown and white) and the black -ive line. According to the manual this latter line goes to the inertia switch before going to ground via a black and violet wire.
When I get the car off the road and onto my drive [don't ask ] I will be checking with my mutlimeter for the obvious etc. What I'd really like to know is, is the inertia switch the same thing as the fuel cut off switch I've read about on here and if it is, is it under that black rubber button to the left of the passenger seat?
Does anyone have the part number for this fuel pump in case I need to get one from the wreckers?
According to the Haynes manual there is a 20A fuse somewhere for the fuel pump (big innit?). Any idea where this is located?
PS - what is the job of the inertia switch [to turn the fuel pump off in the event of a collision?]
In anticipation
Dave
I'm gettin' too old for this car repair malarky
________________________________________
davet30 is offline Reply With Quote Quote
Old 17-11-2007   #2
Trader Rating: 1
SlinkyCinqi has donated!
Re: Suspect Fuel pump failure on this 1999 S 60
hi there, the inertia switch is the fuel cut off switch yes i'm not too sure where it is on a punto though (i'm a cinq boy lol) But if you get in the car and turn the ignition on, you should be able to hear the pump priming.
As for the cut off switch the fuel pump is earthed through it, so when the NC contact in the switch breaks the pump has no -ve feed. And yes, it is to cut the fuel pump off in the event of a collision.
The fuel relay could also be your problem? It is under the bonnet in the engine bay, and is a rectangular white box (near the ecu, along with the fuse in a cinq anyways) have alook for that and check the plug is in properly and the contacts are clean.
Hope this sheds some light on your situation
Lenny
SlinkyCinqi is offline Reply With Quote Quote
Old 17-11-2007   #3
arc
this is where i stand
arc has donated!
hi.
the inerita switch is to cut the pump when there is a collision or other large jolt. Hit a big enough pot hole and it can set them off.
when you turn the ignition on, you should hear the pump prime. if you don't - it does not always mean a pump failure. it could be the fuel pump relay, fuse, or the interita switch.
the system is easy to test if you've got the diagrams and a meter in front of you.
do not pay them prices for a new pump. http://www.frogbitz.co.uk if you want a new one - or scrap yard prices.. i paid about £40 for a Punto 85 pump. The pump itself is a common part, so you you'd get away with buying one from another car and then swapping the pump over from the carrier.
.:: 1368cc 16v Cinquecento ::.
arc is offline Reply With Quote Quote
Old 17-11-2007   #4
Thanks for the speedy reply(s).
Would it be fair to say that if I was getting a +voltage with respect to -ve at the pump contact on turning the ignition on then the problem would not be the relay/fuse? I think I'm right but thought I'd ask.
Also, in my mechanical days to prime a pump was to fill it with the fluid you intended to pump with it. Is this what you mean when saying hear the pump rpiming or were you refering to the pump priming the system? i.e. making sure there was a fuel pressure at the carb inlet?
Dave
Old 17-11-2007   #5
the noise you are meant to hear is the pump itself simply filling the sytem with fuel ,once it reaches the injectors/carb it will stop until you start the car when the pump obviosly kicks in again, not very loud more like a faint buzzing -- the cut off switch on a mk 1 punto is by the side of the passenger seat between seat and door you cant miss it
Thanks davet30 thanked for this post
jaybee is offline Reply With Quote Quote
Old 18-11-2007   #6
Quote Originally Posted by jaybee View Post
I'm interested to know what causes the pump to stop once it's primed the system and before the engine is started? Does it stop or is their an unloading valve in the system? If it does stop I'd be interested in what makes it stop as this could have a bearing on my fault finding exercise.
btw, is it a possitive displacement pump or centrifugal type?
Dave
Old 18-11-2007   #7
what sort of system have you-spi?-mpi? these are controlled by fuel pressure regulator and the ecu-- pre 1998 have seperate system, post 98 the whole system is integral part of fuel pump,
Old 18-11-2007   #8
I know this is not very "health and safety" but if I remember rightly on the top of the fuel pump there are two arrows on the feed pipes why not simply disconnect the pipe feeding the injectors and turn on ignition you will at least have a visual check to see if pump is working
this item is on ebay for around £50--item number 320183139782
Old 18-11-2007   #9
Bravo 1.8 HLX FTW
The Sultan's Avatar
The Sultan has donated!
the fuel pump/injection relay the white thing people are talking about is controled buy the engine ecu it's on a timer as there is no fuel pressure sensor
if you have live it should stop within a few seconds after turning on the ignition
all you need to do is check the continuity between pump and earth
if you have the hatch under the back seats up you will defiantly be able to hear the pump if it's running
so then it's just a case of replacing the pump
i think 55 60 75 80 90 and gt are al the same pump
but i'm sure someone will correct me on that now
500 door handles fit bravo well chuffed
The Sultan is offline Reply With Quote Quote
Old 20-11-2007   #10
Quote Originally Posted by littlepip17 View Post
OK thanx 4 that.
I have now got the thing on the drive (the car that is) and guess what? the RAC man was not right. I have no power to the pump after turning the ignition on (save 4 a few mA) so I am now focasing my attention to the electrical circuit. It's not the cutoff switch cos I tried a different earth path from the pump (the sender eart actually which I tested before hand) so it's definatley a fault on the +ve feed. Nerxt stop I think is the relay. I've located a white relay under a black plastic cover bolted to the bulkhead just to the right of centre. The contacts look fine. My next plan is to interrogate the Haynes manual and take it from there.
At least it will be cheaoper than a pump :-)
Old 20-11-2007   #11
Bravo 1.8 HLX FTW
The Sultan's Avatar
well if the pump is not running first things to check are that the code light on dash illuminates for 0.7 seconds and goes out and that the injection light goes out after about 7 seconds
if these are normal then the code system is functioning correctly
after this the only things to check are fuse relay and wiring to pump
if you clean off the top of this relay there is a wiring diagram numbered with pin numbers
if you look in the plug there are pin numbers next to the pins
it's basically 2 relays in one
one single normally off switch
and a make brake switch
there are also diodes in series with them to look for when manually testing the operation of the 2 switches
but if you can make them both click when powered that's a good sign as coils fail more regularly than the contacts
for example if you power pin 7 and earth pin 14 one should click
and if you power pin 3 and earth pin 10 the other should again click
if the code light does not go out
there are a few reasons for this the code box may not be functioning or the key code aerial may be damaged or the engine ecu may have not accepted the code due to failure
if there is no code light at all
check the permanent live
switched live
and earth to the code box near the internal fuse box on drivers side with 2 plugs to it it's a small black box
use a test meter and make sure the permanent live is the full 12v as below 9v it will not function
switched is orange and has a 7.5amp fuse after the ignition switch in the interior fuse box and goes to pin 8
permanent is red it goes thou the under bonnet 40a ign fuse then a 7.5a in the interior fuse box and to pin 3 on the code box
earth is black pin 4
ps do not use other circuits to earth the fuel pump or any other high power equipment you may seriously damage some wiring as it's not designed to take high current
Old 20-11-2007   #12
I was intending to do just that re powering the relay coils but I wanted to check that the inputs were 12v first before 'blowing' anything up.
To do this I was going to put a meter across the socket pins 8/15+ve and earth and also between 12+ve and 7-ve
Will I be ok to power each solenoid then with a 12Vdc supply?
Thanks for your thorough reply and I take your point about using secondary earting on a 20A circuit.
btw, if I don't get a 12v supply on pins 8/15 this would point to the 20A fuse - physically where is this located?
Old 21-11-2007   #13
Bravo 1.8 HLX FTW
The Sultan's Avatar
the fuse is mounted on the metal cage infront of the relay under the plastic cover if not this circuit does not have one other than the main 40a ign fuse
don't try and manipulate the relay on the car you will brake things it's controlled at crucial times buy the engine ecu and ignition key and without a full wiring diagram you wont know what should happen when you do it
it controls lots of functions within the ecu not just the fuel pump
your ok to use the cars battery to test it disconnected or could even use a test meter to check continuity across the windings
Old 21-11-2007   #14
Thanx for the advice.
I had the relay in my house and using a 12vdc power supply. Got both relays to operate and output switches triggered just fine.
I tested the 20A fuse by checking I was getting 12v at pins 8/15 and that was fine.The thing to check next was continuity between pin 4 and the pump supply (both brown and white wires.
NB There was no contact for pin 4?? but since these are all commoned up within the relay to pins 5,6 and 13 I wasn't too bothered at this point as the system was workingf at some point.
Not a sausage between these two points (pins 5,6 or 13). According to Haynes manual there is a connector between these two points located somewhere in the fuse box.
A bit of luck here ... just about the only brown and white wire visible within the nest proved to be the right one as I got continuity between it and the pump :-)
On testing between this and the relay socket though began to show strange readings??!! -- but I realised my mistake. Because of the distance I was using wires on crock clips and one must have been touching to earth causing these strange readings. Anyway to put it in a nutshell I appear to have a break in a wire between this connector in the fuse box and the relay socket although it may well be somewhere else as pin 4 does not exist. Must be tied up to either ignition coil, canaster solenoid, fuel injector or heated lambda sensor.
If anyone has any better drawings than those supplied by Haynes manual showing the actual connection and would like to share that knowledge with me it would be much appreciated.
Thanks again.
Old 21-11-2007   #15
Bravo 1.8 HLX FTW
The Sultan's Avatar
is this usefull
were it says n.d. next to a wire with a dot and the colour codes in andout that's an ultrasonic weld in the harness things to look out for if your trying to find a break these do from time to time
this might be good too
shows the relay but i cant quite find the fuel pump yet
(G) How many bravo/as? sammiboo Bravo / Brava 255 28-02-2008 22:34
(G) Sei 16v fuel pump thoughts J.R Racing Cinquecento / Seicento 5 27-10-2007 01:03
(T) what fuel pump do i need m reg 90 elx i? saralou29 Punto (Mk1) 3 06-07-2007 13:40
(T) Fuel Pump Knacked?! mishnish Punto (Mk2/2b) 2 03-03-2007 18:06
(G) What fuel do you use? Lightman Stilo 42 25-11-2006 18:42
