General Changing steering wheel.
Didcot
My punto currently has a standard steering wheel, and ive located one of the sporting steering wheels with the silver ring in the middle. Is it easy to change steering wheels, and how do i go about doing it? I want to know how before i purchase it.
Mike.
is the steering wheel local to you, as you could trial fit it, also you'll need the airbag, its an easy job, disconnect batt, undo 3 allen bolts on rear of wheel to remove airbag, disconnect wires, remove large center nut and pull off the wheel (thats the hardest bit)
