Having some issues with my MK1 85 16v at the moment. On cold mornings its reluctant to start. Usually it turns slowly and fires up on 2 or 3 cylinders you can clear it by revving it a little. The worst case was a couple of days ago when on turning the key the 1st two times the car appeared to forget it had an engine, turning the key switched on the fuel gauge, and the airbag light but nothing else happened, the engine didn't turn, the battery light didn't come on and neither did the management light. It started reluctantly on third go. The car always goes in the end and runs fine for the rest of the day but doesn't like first start of the day. I suspect battery may be getting a bit weak but anyone else got any ideas?
