Old 17-10-2007   #1
Smile Choking engine light flashing when accelerating
Hello, so glad to have found this site !
Maybe someone has Had a similar problem…
I have a 2001 1.2 Punto (known as Mia) it s got about 45000 miles on it and a small while back when i accelerated it started to choke slightly and the light on the dash went on (the one with the engine)
So being a girl when this passed I thought nothing of it…and it s still happening ofcourse more then before L
This happens nearly every time I accelerate/ well when I start of in a gear (mostly 1st and second…occasionally third)
I know I ve gotta go to a garage ASAP cos that’s what the little book in my [COLOR=#f77e1d! important][COLOR=#f77e1d! important]car[/COLOR][/COLOR] said but I would love to hear from anyone who knows what this could be or who has had a similar problem…
Thankyou Fiat lovers!!
meems is offline Reply With Quote Quote
Old 17-10-2007   #2
Re: Choking engine light flashing when accelerating
The first thing I'd try here would be a new set of spark plugs, they're cheap and fairly easy to fit. When was the car last serviced?
Racing is life. Anything before or after is just waiting!
chris.fulton is offline Reply With Quote Quote
Old 17-10-2007   #3
Punto.Power has donated!
I would do what chris has said try replacing the spark plugs, you could also replace the ht leads and see if that cures your problem if not though it could be anything when the engine management light is on, best bet and fastest option would be to put it on a diagnostic machine then see if any errors come up.
Punto.Power is offline Reply With Quote Quote
Old 24-10-2007   #4
I appear to be having the same/similar problem, but I'm using the car at night when it's at it's coldest and dampest, I'm going to try WD40 around the engine electrics first and see what happens. Then maybe work back from plugs and leads, and try a bit of trial and error from then on. I can't believe it can be the plugs, but then, I'm no mechanic.
bkr57 is offline Reply With Quote Quote
Old 20-11-2007   #5
Back again, I mistakenly bought and replaced ECU (they ain't cheap), but after having it looked at by a mechanic, he found that the plugs leads were arcing, and replaced them, along with a new set of plugs, so all's well at the moment.
2001 Punto, 1.2 8v. And when the weather is fine, a 2000 Yamaha Fazer FZS600, slighty mod'ed.
(T) Brava 1.9td glow plug light flashing after plugs replaced Gort Bravo / Brava 12 27-05-2008 11:11
(T) Engine Management Light Flashing Craig_uk Punto (Mk2/2b) 2 17-10-2007 16:32
(T) Engine Management System Light sh33n Punto (Mk2/2b) 11 17-04-2004 23:21
(T) Engine Control light flashing jonnyyeah Bravo / Brava 1 13-03-2004 03:52
