Technical Component Locations
Shaunyboyuk
Here is a diagram and labels for various engine manangenet compent locations. Got this of a mate who has autodata, will post up some more info soon. The Diagram covers mk 2 and mk 3 puntos 1999-2004
Components:
1. Camshaft Position Sensor (CMP)
2. Crank Position Sensor (CKP)
4. Engine Control Module (ECM)
5. Engine Control (EC) Relay
6. Engine Coolant Temperature (ECT) Sensor
7. Evaporative emission (EVAP) canister purge valve
8. Fuel Filter (IN TANK)
10. Fuel Pump (IN TANK)
11. Heated Oxygen Sensor (H02S) - Before Cat
12. Idle air control (IAC) valve
13. Ignition coil
15. Injectors
16. Intake air temperature (IAT) sensor - IN MAP SENSOR
17. Knock sensor
18. Manifold absolute pressure (MAP) sensor
19. Throttle position (TP) sensor
20. Vehicle speed sensor (VSS)
Diagram:
Nice post! Would be brilliant for all models too (y)
Il find out tomorrow as he hasnt updated it yet as i have his diagnostic laptop :p
