Technical rear window wiper and washer.
adam_bird1987
hi
I have a FIAT PUNTO 60 1.2 (97-99) SX 3DR and the rear window wiper doesnt work and when i spray the rear wash it doesnt come out the hole but stays in the boot.
I was told to check the connection to the window wiper but where is it and how do i do this. i was also told that there is probably a slit in the pipe that carries the wash to the window. once again how do i check this and fix it as id rather not go to the garage to get ripped off for something i can easily check myself.
Thanks and any advice would greatly be appreciated.
It'll be seized thru lack of usage, its common on the mk1 punto.
Very unlikely anything wrong with the stalk wiring, contrary to popular believe fiat wiring is very good.
Just get a replacement (scrappy) wiper motor. Make sure the one you get is sat in its normal position though, stuck halfway across the glass = thats also seized.
You should be able to pick a motor up for £5-10.
Thanks for your speedy replies.
Bit of a dumb question, where do i find the pipe in the boot? is it under the plastic cover on the boot door that i can just unscrew and pull off??
Thanks again and soz for my complete lack of car knowledge!!!!!
