Technical mk2 punto 12 16v elx HELP!!!!!!!!!!!
chrisac46
PLZ HELP!! ENGINE KEEPS REVVING UP ON ITS OWN, WHEN ITS HOT IT WONT TURN OVER, LIKE THE BATTERYS FLAT? BUT STARTS GREAT WHEN COLD, ECU LIGHT COMES ON WHEN REVVED UP? IM READY TO BURN IT!:bang:
try replacing the top dead centre sensor around £30 thats what it was with mine
USING IMPACT TEXT DOSE NOT GIVE YOUR POST MORE IMPACT IT JUST MAKES IT HARD TO READ
get it plugged in at fiat you have way to many problems to start asking on here
you wont get any were
some of your problems are to do with an ecu update you may need on the engine ecu
the non starting maybe a wiring fault or ignition switch fault(does it actually fail to turn over)
over revving may be an icv or ecu update related
