Old 30-05-2004   #1
Fuel tank breather
Hi, I have a severe performance problem with my 96 Punto 1.1
The car pulls and jerks all the time. I've had the onboeard diagnostics checked and apparently they are fine.
However removal of the petrol cap reveals what I would class a abnormal amount of suction so I suspect the fuel tank breather is blocked, can anyone describe which is the breather and if the tank vacuum is normal, I don't think it is.
Sorry if this seems a stupid question but it's been going on now for over a year and it's driving me mad.
Peter
Bogul is offline Reply With Quote Quote
Old 30-05-2004   #2
modern cars do not have fuel tank breathers too comply with hydrocarbon emission regs, effectivly the tank is vented too a carbon filter which is inturn conected too the inlet manifold by a ecu controled valve.
also just because there are no errors in the onboard diagnostics does not mean all is well with the injection system.
uno 1.0ie RAAAWW!
kebab is offline Reply With Quote Quote
Old 30-05-2004   #3
Ok Kebab, Thanks for the info but is the tank vacuum normal or is the problem elsewhere?
Peter
Old 30-05-2004   #4
i dont know, they all hiss when you remove the filler cap but weather or not thats a vacum or positive pressure i just dont know.
regardless of that run your engine with the cap off, if it still plays up then you know thats not a problem.
uno 1.0ie RAAAWW!
Old 30-05-2004   #5
thefishdude has donated!
Balloony Champion, Bee Wars Champion, Submarine Champion
sister had jerking problem.....dam that sounds wierd....anyway as i was saying my sister 1.1 had a jerking problem turns out just to be new set of plugs needed :) and al sorted after that. could also be coil pack.
2001 Punto sporting in sprint blue with matching Mr Bump air freshner all together now mmmmmmm
thefishdude is offline Reply With Quote Quote
Old 02-06-2004   #6
I too had the same problem and it turned out to be the spark plugs. I had them changed and the problem stopped straightaway.
no1sourlung is offline Reply With Quote Quote
(G) Fuel tank filler vent blocked and cut outs Mazz0 Uno 9 22-07-2015 09:44
(T) Cinq Fuel Tank DeeDoubleYoo Cinquecento / Seicento 4 17-07-2004 03:15
fuel tank leaking on my Punto IainB Lets Talk FIAT 10 10-02-2004 16:03
(T) Cinq Fuel Tank\ Fuel Guage arseofbox Cinquecento / Seicento 0 25-09-2003 03:35
(G) is it the fuel pump or a blocked tank vent.. lashlondon Uno 8 24-09-2003 21:58
