| Thread Tools |
![]() | #1 | ||
Posts: 3 Thanks: 0 Trader Rating: 0 | Rear Brake Lights Can anybody help? My rear brake lights are not working.The bulbs are ok and the fuse is ok. Could it be the switch on the brake pedal? I don't know.Can anybody help
![]() | #2 | ||
Posts: 478 Thanks: 0 Trader Rating: 0 | could well be, best way too test it is too bend a paperclip into a u shape and use that too short out the switch. If the lights work then you know its the switch, well thats the way i allways do it :D uno 1.0ie RAAAWW!
![]() | #3 | ||
Posts: 3 Thanks: 0 Trader Rating: 0 | Thanks. I'll have a go in the morning.:D
![]() | #4 | ||
Posts: 3 Thanks: 0 Trader Rating: 0 | Tried that but it didn`t work. Any other ideas?
![]() | #5 | ||
Posts: 55 Thanks: 0 Trader Rating: 0 | Pull the plug off the switch and they should be on! When the switch is pressed the brake lights go out.
![]() | #6 | ||
![]() | ![]() Originally posted by D.White Motors Pull the plug off the switch and they should be on! When the switch is pressed the brake lights go out. Unplug the connector and short the two contacts together; then the lights should work. <font color="navy">Punto 55SX</font id="navy"> ![]()
![]() | #7 | ||
Posts: 478 Thanks: 0 Trader Rating: 0 | should be 12 volts on one of the terminals at the switch, i would check that next. uno 1.0ie RAAAWW!
Thread Tools | |
![]() | Body Stylist | Punto (Mk1) | 30 | 09-04-2005 18:02 |
![]() | hoyley_boyley | Bravo / Brava | 1 | 17-01-2004 01:07 |
![]() | Bois_aiii | Cinquecento / Seicento | 4 | 24-09-2003 05:48 |
![]() | Ceggy | Punto (Mk2/2b) | 1 | 24-04-2003 02:28 |
