Old 04-07-2007   #1
sump replacement
hi, looking for help!
my garage says that the sump to my X reg Punto needs replacing. To save money, Ive tracked down a new sump off ebay and have asked my garage to fit it. My garage say they will need 'sump gaskets' too so they can fit it, but i cant find mention of these anywhere amongst parts sellers. Can anyone clarify, will just a good sealant do???
balajit is offline Reply With Quote Quote
Old 04-07-2007   #2
Trader Rating: 10
dave has donated!
Re: sump replacement
use a different garage. they don't have gaskets they use a sealant
“The further a society drifts from the truth, the more it will hate those that speak it.”
Old 04-07-2007   #3
oh thanks. that makes sense.
is there a particular type of sealant i should get....??
Old 04-07-2007   #4
Trader Rating: 10
dave has donated!
yes RTV sealant
Old 04-07-2007   #5
I am told the fiat sealnet is best and is only £3 anyway.
Ex punto mk2 owner 1.2 8v with 94bhp.
Now owns a seicento sporting abarth bog standard and loving it!
Lowtechguy is offline Reply With Quote Quote
Old 04-07-2007   #6
Trader Rating: 10
dave has donated!
Quote Originally Posted by Lowtechguy View Post
some one on psc said it was £14, RTV in a mastic gun cartridge from motor factors is only couple of quid and mastic gun is only £1 form poundland
Old 04-07-2007   #7
Oh right, much better solution.
Although I apply the sealent to the sump then hold it up so tube or gun the application is easy anyway.
Old 04-07-2007   #8
I used Loctite Sump Sealant....#98 if I remember rightly.
crabbo_1 is offline Reply With Quote Quote
Old 05-07-2007   #9
Bravo 1.8 HLX FTW
The Sultan's Avatar
The Sultan has donated!
fiat glue is about £14 but it is defo the best
cut the end of the tube so that you end up with a point of glue sticking up from the sump this way you will get the best seal and make sure the surface is clean and free from oil
when you hold it up to the engine don't let it drop again or it will bugger the seal maybe get someone to put the four nuts on wile you hold it then put the rest of the bolts in
ps. you will need the dipstick out to fit the sump
The Sultan is offline Reply With Quote Quote
Old 05-07-2007   #10
thefishdude has donated!
Balloony Champion, Bee Wars Champion, Submarine Champion
was told by fiat guy that the sealer requires 24 hours to cure properly before you can use car. just thought i would mention it lol
2001 Punto sporting in sprint blue with 2 Mr Bump air freshners and a new clutch and flywheel mmmm
thefishdude is offline Reply With Quote Quote
Old 05-07-2007   #11
Bravo 1.8 HLX FTW
The Sultan's Avatar
rubbish leave it for an hour before punting new oil in then you can drive it the heat will help it cure
Old 05-07-2007   #12
Trader Rating: 10
dave has donated!
i recomend 24 hours as well
Old 05-07-2007   #13
Loctite says 24hrs.
Old 29-12-2008   #14
Hi
I recently replaced the sump on a 1.2 Mk2 punto after breaking through a very corroded sump supporting the engine whilst changing the timing belt.
Since changing the sump and using hylo-mars red gasket seal the engine leaks oil. However it doesn't appear to be coming from the sump seam, rather up in the engine/gearbox join.
Is it possible that the crank seal has been disturbed when moving the engine around and are these supposed to be changed when fitting a new sump?
Any suggestions would be great as I'm spending more on oil than petrol at the moment!
Jonp87 is offline Reply With Quote Quote
(T) Punto Oil Sump Replacement STEPHEN P MORGAN Punto (Mk2/2b) 3 30-06-2007 22:09
(T) Brava 1.4 Sump Replacement Big J Bravo / Brava 0 27-05-2007 20:28
(T) Anyone Help With Barchetta Sump zoeh Barchetta 22 21-04-2007 20:42
(G) Sump swop? 190daj Cinquecento / Seicento 7 06-06-2006 09:39
(T) Marea 1.6 Weekend Sump Leak George Kidd Marea 2 19-02-2005 14:49
