edmundo New member Joined May 4, 2006 Messages 101 Points 32 Location Surrey Jun 26, 2007 #1 This may sound stupid but is the timing belt the same as the cam belt? I.e its the same thing just two names used to describe it?
Chris@souls Patron member Joined Jun 19, 2007 Messages 1,557 Points 274 Location Milton Keynes Jun 26, 2007 #2 Yes mate
OP OP edmundo New member Joined May 4, 2006 Messages 101 Points 32 Location Surrey Jun 26, 2007 #3 Thought so, cheers. Lastly when doing the timing belt im guessing its best to do the tensioner at the same time? Ive also been told that its worth doing the water pump aswell, is this true? By the way its a mk2 16v
Chris@souls Patron member Joined Jun 19, 2007 Messages 1,557 Points 274 Location Milton Keynes Jun 26, 2007 #4 i always sell cam belts as a kit and would recomend checking the water pump
OP OP edmundo New member Joined May 4, 2006 Messages 101 Points 32 Location Surrey Jun 26, 2007 #5 Ok thanks for that. Cheapest ive seen the 3 parts for is on shopr4parts at £73.01. Does that sound about right?
Chris@souls Patron member Joined Jun 19, 2007 Messages 1,557 Points 274 Location Milton Keynes Jun 26, 2007 #6 If its a 1.2 16v mk2 punto it needs cambelt and 1 tensioner, gen fiat kit is £50 post your chassis no. or PM me your reg and i will check it out for you
