Technical Windscreen washer fluid leak
nauzad
Ive just got a Punto S60 and am figuring out how things work :D I tried filling the windscreen washer fluid a couple of times but it seems to be draining out in a couple of hours.
I can see a small round cylinder (smaller than a 5p coin) close to where the pipe from the windscreen washer reservoir comes out.... and thats leaking. I was told by a mechanic that thats a pressure valve :eek: but i doubt thats true. Whats it and why is it leaking.
Any easy way to check if the tank itself is leaking (since its not easily accessible)?
That small cylinder should have a little arrow on it? It is a one-way valve and thats almost certainly what the problem is. Seems like lots of mk1s have this problem, mine had it too. Just buy a new one from halfords mate. Don't go through the hassle of checking the tank because it's probably the valve and the tank is an absolute MISSION to get out. (y)
Ive had my punto 75SX 3 weeks, and It leaks on mine, yet It only started leaking a week ago, guess it is a common problem.
