andrewb
My sister's Punto was misfiring and I diagnosed it as a coil. (If you pulled the plug on the suspect coil, it made no difference to the rattling of the engine). The manual I have for a MK1 punto says that the resistance of the primary winding should be between 0.495 and 0.605 ohms. The suspect coil was 1.7 ohms. 'Aha!' I said and bought a new pattern part coil. The new coil didn't fix it and when I measured the resistance, it was 1.8 ohms.
Have I bought a faulty coil? Should I get a proper fiat one? Can anyone confirm that the info I have on the resistance is correct?
Apparently if the ecu detects too high or too low resistance in a coil, it shuts down those 2 cylinders.
