General are the badges
fallen angel
are the badges on the back of the mk2a punto stuck on or screwed on? if they r stuck on n i pull them off will it damage the paint? is there any special ways to get them of easily without damageing the car's paint work?
Some hot water and a credit card will get 'em off.
I did it last week, and found my paintwork was damaged so had to put them back on.
The badges are only stuck with glue, and if you take them off carefully, you definetely wont damage the paint... nothing to worry about, just use some warm/hot water (not boiling or the paint will bubble) to soften the glue (You can also use a hairdryer). then peel them off and use a credit card and some Rexin / T Cut (polish) to remove the remaining glue... should come off easily and will take approx. 30 minutes...
lol...approx 30mins...thanks 4 ur help guys will give this a go later.
thanks agen(y)
