im wanting to replace driveshaft oil seal on passenger side of gearbox...
i can easily remove driveshaft from gearbox end, as its bolted into a rotating hub/shaft thingy, not sure the correct name, but...
how do you remove this hub/shaft that goes into the gearbox(diff) its part of the gearbox, not the driveshaft....
someone told me you need a tool to prise it off, what tool would this be? and where would i get one from.
cheers...
cheers...
