General will the grande punto rims fit the normal punto? with tyres at 215/45/17???
FeRRaRi_oNuR
hi there mate do you think they will fit? or will the grande punto alloys which is 6.5x17 fit the 205/4-0/17 tyres? pls help i need original rims 17's im after
hi there mate i already have wobbly bolts however i use to have fox racing alloys with the fitment of 4x100 and the center bore did not sit in properly even with the right spigot rings? and the car was vibrating at 60mhp and got worse if you did more. will i have the same problem? also i was using 7mm spacers on the rear with 205/40/17's . will my tyres go on the grande punto rims? will the center bore be the same? any ideas ppl thanks
