Link to video of sound: https://streamable.com/o0k5pa
Hello,
This problem started recently and I can't think of a particular reason why.
It's a 2011 Punto Evo 1.4 petrol at ~75k miles.
In neutral, there's no noises. I can rev the engine and it's fine. I can also press the clutch in and out and there's no noises at all.
When pulling away with the clutch half pressed, the noise is greatest. It is also heard when switching gears or briefly when pushing the gas pedal all the way down whilst moving.
While cruising, it's completely fine.
I cannot see any difference between going straight or whilst turning. There's also no difference between going up or downhill.
The timing and accessory belts were replaced 1000 miles ago and both look fine with normal tension.
I took it to one mechanic who says it's the clutch
Thanks for your time.
Hello,
