![]() | #1 | ||
Posts: 4 Thanks: 1 Trader Rating: 0 ![]() | Brake Failure Hi Fiat forum, its been ages.... So my Punto is due an MOT next week so am at "dad's garage" for a check over. Front wheels off, osf wheel bolts ridiculously tight. Local garage changed a coil spring about a year ago, so vastly over tightened. Anyway, all good on NSF, applied brakes so the disk won't spin whilst wheel bolts were freed and lubed, all good, wheel back on. Same treatment for the OSF. Placed foot on brakes like NSF attending to very stiff bolts and BANG! something dripping on face. It wasn't water... Brake peddle straight to the floor. Bugger. Brake hose has blown off the union! The metal pipe is unioned to the metal end of the flexi hose, being swagged, the metal swagging part under the thick rubber strain relief part of the hose. Very bad corrosion as seen in the picture. Very lucky to have this happen whilst stationary. Had this happened in an emergency situation, the minded boggles at the thought. Be warned, they may look fine, yet be ready to fail. Hose now out of the caliper as is the nipple and the union free of the rusty flexy pipe end. Typical this should be a long bank holiday weekend. Hopefully local shops should be open again tomorrow for two new brake pipes. A 60 plate vehicle with 72k miles. Once front is done, the rears will get a service. New shoes a possibility, cylinders if needed and flexi hoses replaced. Cross fingers, eyes and toes....
![]() | #2 | ||
Posts: 4 Thanks: 1 Trader Rating: 0 ![]() | Picture mentioned above
![]() | #3 | ||
Posts: 4,272 Thanks: 311 Trader Rating: 0 ![]() | Re: Brake Failure Oh my goodness. That is a shocker. From picture looks like the swaged part of the union parted company from the union years ago due to corrosion. only the very small metal tube inserted into the hose was holding it together. I will make a metal note. Thanks
![]() | #4 | ||
Posts: 78 Thanks: 12 Trader Rating: 0 ![]() | Re: Brake Failure Yes, a really lucky escape, could have well been a tragedy waiting to happen. All other brake hoses will be changed.
![]() | #5 | ||
Posts: 3,455 Thanks: 177 Trader Rating: 0 ![]() | Re: Brake Failure Lucky indeed, but this is down to lack of servicing. Sorry if this sounds too frank, but facts are facts. Brakes seem to be top of the list of being least looked at. Glad you’re going to be changing other hoses.
![]() | #6 | ||
Posts: 78 Thanks: 12 Trader Rating: 0 ![]() | Re: Brake Failure The thing is it look fine, the thick rubber strain relief tube covers the swagged part, so no real way of checking...no leak, no staining, it just blew off. But yes, moral is, change hoses every 5 years or so from now on. Merc service/change interval is 3 years, but if you can afford a Merc you can afford the bills...
![]() | #7 | ||
Posts: 27,876 Thanks: 1092 Trader Rating: 0 ![]() | ![]() there does appear to be a fair degree of corrosion ![]() Ive got 2 x 2013's they still have the zinc inplace Merc changing it all at 3 years.. They will be up in court for environmental misuse ![]() Edit : your failure seems 'unique'.. But I was thinking..'nobody ever changes the clutch hose'- WRONG.. The modern 500 has an appetite for the union on the innerwing 1 to 3 years appears 'normal' ![]()
![]() | #8 | ||
Posts: 3,304 Thanks: 174 Trader Rating: 0 ![]() | Re: Brake Failure Sounds like a good place to give a liberal coat of anti sieze in future hopefully keep some of the rust out
![]() | #9 | ||
Posts: 3,628 Thanks: 342 Trader Rating: 0 ![]() | Re: Brake Failure Rather a shocking failure this which I've actually never come across before. Thinking about it though it's entirely logical that it might fail in this way. Back in my instructor days I was always very strict with my lads that they fully support things like calipers and not let them hang on the flex hose. This was usually accepted without question but on one occasion two "smart Alecs" decided to "get clever" about it so I set them a wee project to write up a wee instruction for me to use in lectures as to why one should or should not allow weight to be taken by the hose. One of the things they found out, which is highly relevant here, is how the metal ends are fitted and secured to the flexible rubber pipes when manufactured. The metal end has a "spigot" over which the hose is pushed and around this is a much larger diameter metal "collar", all part of the metal end, which is then crimped over the hose to hold it. Think now about how this works in service - when the fluid in the hose is pressurized it will try to expand the hose and leak out between the spigot and the end of the hose. The crimped collar tends to stop this happening anyway but the internal pressure is attempting to expand the rubber hose against the collar. This actually locks it even more securely in place and stops the hose coming off the spigot. If the crimped collar wasn't there the hose would expand and just blow off the spigot, Which, because it was badly corroded, is exactly what happened here. Think now though about what you are doing to this crimped connection if you let a heavy caliper "dangle" from it. You are now applying a force in tension to the rubber hose and it's not designed to withstand this. By pulling on the hose you are elongating and "thinning" the side wall rubber of the tube which could pull it out of, or, more dangerously, partially out of, the crimped fitting making it much more likely to then fail when pressure is applied during braking. So, DON'T LET "STUFF" DANGLE FROM BRAKE HOSES! I have to admit I'm always careful to take a good look at metal brake pipes when working on any of the cars and I usually flex the hoses to look for external cracks but, I've just realized, I don't look all that closely at the flex hose ends. So now I'll be taking a very careful look at Becky's hoses in the near future when I'm tackling the rear axle corrosion.
![]() | #10 | ||
Posts: 78 Thanks: 12 Trader Rating: 0 ![]() | Old hose remains... Just rust ! Anyway new hose fitted. The lad had to walk the mile or so to the factors in the snow, hose arrived at 3pm today.
500 Brake failure | Sylverah | Newbie Central | 2 | 08-11-2015 10:55 |
![]() | JamesTGP | Cinquecento / Seicento | 13 | 03-03-2010 21:25 |
![]() | Jedidev | Bravo / Brava | 11 | 26-08-2009 16:35 |
![]() | scottyJTD | Bravo / Brava | 16 | 17-01-2008 09:27 |
Brake failure | Neelu | FIAT Boo Archives | 5 | 02-06-2002 23:13 |
