Technical Glove Box removal 2013 Punto Evo
kadirh2
Can't find the answer here by searching.
How do you take out the glove box of a 2013 Punto Evo so that the pollen filter can be changed - more specifically I keep breaking the silly plastic lugs on the cover; Haynes manual says that there should be a screw at the bottom of the glove box but this is not the case.
Anyone know where you can get a decent workshop manual for the evo
If I have success I'll post pictures for others
Halil
Halil
Hi :)
You have confused me
In UK ENGLISH :
Glove box.. is the door and 'cupboard :box' directly above the passenger footwell
The pollen filter :
Under radio:cd
Bottom of the central heater unit ;)
Guide shown below for Grande Punto.. same design..
look for the Gold Coloured screws ;)
Found this.. in a UK model FIAT :)
The photos show the glovebox door and the heater unit..
then removal of the screws.. black cover
And sliding out the filter :)
It will be good to see your pictures (y)
Charlie
Haynes manual for the punto ( 5956, 55 to 15 reg) says to remove the glove box:
1) Remove the passengers glovebox as described in chapter 11 section 25
2) Carefully praise the rear edge of the passengers side console front trim panel outwards, and manoeuvre it rearwards from place
3) Undo the retaining screw and remove the pollen filter cover
4) Withdraw the filter from its housing
5) Wipe clean the housing, then fit the new filter, noting the arrows on the filter element must point rearwards
6) Refit the centre console panel and glovebox.
Tried it as per video, got the new filter in but on trying to put the pollen filter cover broke the upper plastic lug as can't see what's happening. Spoke to Fiat dealer re getting a replacement cover who advises that other people have reported the same thing happening.!
chapter 11 section 25 refers to Facia panel removal and refitting
Glovebox removal:
1) Open the glovebox and use a small screwdriver to extract the outboard plastic hinge pin
2) with the hinge pin removed, manoeuvre the glovebox from the facia
Refitting
3) Refitting is a reversal of removal
Should have gone through the manual a few more pages, - for Punto Evo / Punto (2012 model year on), my car, glovebox instructions are:
1) Carefully prise the glovebox light from place, and disconnect the wiring plug.
2) Squeeze together the lugs and remove the retaining pin securing the glovebox lid support strap.
3) Lower the glovebox lid, depress the clip on the plastic bracket and manoeuvre the lid from the facia
4) Release the clips and pull the glovebox tray rearwards from place
5) Undo the 6 retaining screws, and manoeuvre the glove box rearwards, disconnecting the wiring plug(s) as they become accessible
Refitting
6) Refitting is a reversal of removal
Shall try once I receive the replacement pollen filter cover
Any help re replacing the pollen filter cover easily would be appreciated as it will save mucking around removing the glovebox
Halil
Thought I'd give removing the glovebox a go, Haynes manual's wrong - screws aren't where suggested and removed screws that I can get to but glovebox is not coming out
The evo and the grande have a different dash and so have a different glove box. They do not come out in the same way, but as I said removing it doesn’t achieve anything of use
From the pictures in the Haynes manual, I'd say the advantage in removing the glove box is that there's better visibility of the pollen filter housing especially the top upon which I assume you need to hook the cover over first before fixing at the bottom.
As I've said, I broke the top plastic hook trying to get the cover on as I can't see what's going on, bottom is visible.
Any guidance on getting the cover back on?
thanks
Halil
thanks
Halil
What number is this Haynes manual?
I wasnt aware they covered my 2012+ ..
Haynes Manual 5956, covers 55 to 15 reg
Apparently I can't post URLs until I have 5 posts! Go to haynes web site and put 5956 in the search box
Covers Punto, Punto EVO and Grande Punto for these years
regards
Halil
