rando
- Mar 9, 2020
- 54
- 13
Hi i need urgent help. My punto evo has a rough idle which has progressively got worse to the point I'm at now. Firstly i checked my spark plugs which had a tiny bit of oil on and some carbon deposits i cleaned these up and ran the car out for a bit no improvement. I then checked the coil pack which is working correctly so i thought maybe change the leads which i did no improvement there. Took it to a garage that said it had a slight misfire recommended putting fuel cleaner through the system. Yet again no improvement. Then i took it to the local garage who put a fault reader in . No faults, he recommended switching to a higher octane fuel as he thought that maybe the cause ran this through no improvement. I cleaned my throttle body butterfly valve out which had a bit of gunk in and no improvement. Checked oil which is fine however my coolant seems to be dropping i topped it up the other day and its nearly back on minium. There isn't any leaks anywhere and i don't know if this is linked but I'm at the point now where i don't have a clue what to do about it.
The car is a 1.4 8v punto evo btw
Any help or advice would be great.
