Hi guys,
I'm a newbie here
I've become the owner of a 2010 Punto EVO 1.4 Turbo Multiair (135ps) like 6 months ago. I bought it with 170k km in it, all in all it seemed to be in good condition. I've changed several things right after I bought it: timing belt, oil, oil filter, air filter....and a few weeks ago multiair filter, and rear brake discs+pads.
Generally, the car is doing well, no error codes etc. However, from time to time I can smell burnt oil, coming from the engine bay...in cold weather sometimes I could even see a bit of smoke..which disappeared as fast as it appeared. I tried to check several times when I saw smoke/smelled burnt oil (by quickly stopping, jumping out from the car and opening the hood), but I couldn't manage to find the source of the smoke.
When I changed the multiair filter and removed the plastic engine cover, I discovered spots of oil on the right side of the engine (if you are facing the engine, so it is the driver side in Europe). I believe that it might be the cause of the burnt smell...the slowly leaking oil, dripping down onto some hot parts of the engine and it burns there. I've attached some pictures, showing the part of the engine where I discovered oil leak (especially around those 2 black pipes, the thick and the thinner one). Has anyone experienced similar on his/her 1.4 Multiair turbo?
Any suggestion is appreciated
Thanks,
Istvan
I'm a newbie here
Thanks,
Istvan
