Greetings from Finland!
I'm new to the forum and quite honestly new to owning Fiat. I recently bought a Fiat Punto Evo with a, how shall we say... questionable past.
The car is a factory-made CNG Natural Power setup, which was initially the reason I decided to get it as our city recently got the first biogas station.
It's a 2012 model, 5-door, dark metallic grey. With the 1.4 8V 77hp engine. 118 000 km on the meter. It has both a 15kg CNG tank and a full petrol tank (45l), so it has a pretty nice range.
The questionable past involves being owned by a Swedish community, then shipped to Finland where someone drove it for three years, apparently changed it at a dealership that then auctioned it. I bought the car from a guy who bought it from the auction and wasn't really honest about its faults. The most concerning thing is that according to the service manual the car has had maintenance only at 66 000 km, 82 000 km and 112 000 km. If those are indeed the only services, it's apparent that the engine has been run on the same oils way too long. I guess the only way to find the real damage would be to open the block and see how the bearings look like. The good thing is that the engine seems to be pulling nicely and sounds healthy, so I'm hoping someone at the Swedish community has been changing oils to her manually and not putting in the service book, but I know this might be wishful thinking.
Now here's the list of things that need fixing:
The other concerns are that there is black/brown residue at the top of the overflow chamber, not in the coolant. The coolant is bright and doesn't have any oil in it. Oil is very clear as well, but most concerningly there is too much of it. The engine also doesn't keep temperature up when driving on the freeway and the air from the heater isn't really hot. I only noticed this once I drove the car home and haven't actually ran her since. I'm really hoping it's just a case of a broken thermostat and overfilled oil, but I realize these could symptoms of a blown head gasket. But like I said, the fluids seem clear and if there was so much coolant at the bottom of the oil pan to raise the oil level, I'd presume it would show in the dipstick and valve cover as sludge. I've booked maintenance for Monday for a thermostat change, oil change, leak down test and wheel angle setup because the car also pulls slightly to the right. Most of these repairs I could handle myself, but I don't really have the facilities or the time currently and it's a hassle to get rid of the coolant and the oil after a change.
Other not so critical, but annoying things include:
- Cracked windshield (250€ at the shop)
- Rear bumper has a crack in it and a small dent in the bodywork above it (I can fix the bumper, but the dent probably needs some PDR work from a pro)
- Right side doors have dents and paint damage in them (PDR and probably touch up the paint myself)
- Rocker panels have lost all paint in the front from the debris flying out of the front wheels. They're basically sandblasted. Not good with our salty roads, no visible rust damage yet though. (Antirust primer, paint, mud flaps. Easy DIY job).
-Rear window mechanism was broken but the previous owner had bought the part and it was a easy fix I already managed to do.
-All sorts of little wore down things. The remote key looks horrible and doesn't stay closed, the rear hatch plastic panel is cracked, boot shelf is missing some parts and other minor annoyances.
-Lot's of little paint chips. Looks like Fiat has had some manufacturing issues with the paint.
So as you can see, a lot of work to be done. I'm not a mechanic but I'm an engineer that actually studied automotive engineering for a year before changing to environmental technology (so from petrol to biogas . The only engine work I've done is pulling apart the valve head of an OHC Opel engine and changing the gaskets and belt while at it. I'd presume the Fiat engine isn't much more difficult than this so I'm not really worried about a head gasket change. If the engine turns out to be completely gone, I will either strip it down myself and take to an engine shop for honing and bearing change or get a replacement engine and change it myself. I have no experience in either but I, fortunately, have friends that can help me out. Can't be that's much harder than changing a cylinder head.
Sorry for the long post and thanks for reading if you made it this far. My biggest motivation for writing this was to get some social support . I guess you guys are the only ones that can understand buying a beat-up Fiat, lol!
P.s. I got the car very cheaply considering the age, but I still think I paid too much for it... I'm going to do my best to bring her back to life but I'm a bit apprehensive of her reliability as a daily driver. I'm also thinking about turning here into a hypermiler and convert the petrol system to bioethanol, so I'd have a range of about 1000 km on near-neutral CO2 fuels. I have no idea how this engine likes ethanol. I guess the only thing I can really change to reduce fuel consumption is the tires, so if you have any recommendations or tips I'd be glad to hear them.
