Google is your friend.
Oh! How did you clean the TB? did you take it off the engine or do it in situ?
I did take off it on the engine and It was very dirty. I used brake cleaner.
As a result, it has been cleaned very well, but I have an idle problem.
Seemingly the throttle position sensor needs calibrated as well, you do this by disconnecting the battery for 15 minuets or so, after that you start car up & let idle for some time. According to what I've read this will re learn the throttle body. Hope this helps.
Probably too well, brake cleaner is for brakes, it’s designed to get rid of grease and oil from brake surfaces and will easily strip the oil and lubricants out of the moving parts of your throttle body, the other problem with brake cleaner is it can and will damage electrical components.
Hunting as you describe can also be a sign of air getting into the intake system south of the throttle.
Assuming everything was working ok before you did this then there is no reason to need to calibrate the tb
Hi. I have same problem as you after throttle body clean there is fluctuation on tachometer. Please did you Solve your problem and how? ThanksHi Everyone Again,
I tried disconnect the battery until 30 minutes, but it didn't work, My problem continues Maybe it will better a little after driving.
